Turbo Oil Leak?
Old Sep 20, 2005 | 02:59 PM
tinks dad's Avatar
Default Turbo Oil Leak?
Just bought an 01 V70 2.4T which has an oil leak on the back of the engine. It apears it's coming out of the turbo oil return pipe seal at the block. Is this a typical failure? Can I remove the return pipe without removing the turbo itself and what are my chances of breaking off the 2 attachment screws?
Bob
Old Sep 20, 2005 | 09:22 PM
Default RE: Turbo Oil Leak?
With a little tweeking the line will come out.
You may have to slightly bend one of the turbo cooling lines to get it to slide out.
The screws will come out easy they very rarely get seized.
Should take you between 30 to 60 minutes depending on how you go about it.
Meaning jacking the car or driving on ramps.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
