Turn Signal Bulb??
Old Mar 22, 2010 | 05:29 PM
family XC70's Avatar
Default Turn Signal Bulb??
Will an 1157A bulb work in the turn signal on a 01 XC70?
Old Mar 24, 2010 | 10:56 AM
65mustang's Avatar
Generally, if the base fits in the socket it will work. Many times the number is only the illumination amount. Like with the new tiny style bulbs with just two contact wires instead of a base? They all fit, just different levels of brightness. And I have never had a problem. (So far) Hehe. Just sometimes my cupholder light looks a freakin headlight. Kidding.
Old Mar 24, 2010 | 11:49 AM
awise1961's Avatar
Isn't the 1157 a double fillament bulb whereas the 1156 is a single?
Al. Wise
Old Mar 24, 2010 | 09:42 PM
Yes,1157 is a double filament bulb. That is what is in there now, parking and turn signal. I think this will work once I figure how to get it out. It is buried behind the air cleaner.
Old Mar 25, 2010 | 03:52 PM
Georgeandkira's Avatar
Default Procedure.....
Hello, THAT bulb was out when I bought my car. Loosen the big air hoses and pivot the top of the air cleaner box out of the way or just remove it. Grab two opposite sides of the box and pull straight up, fairly hard. It pops off little split-barb mounts. Access to the bulb is now easy. Yellow coloring had flaked off my old bulb and I used canned air to blow the flakes out. I put a dab of silicone grease on the barbs to ease replacement. It pops back into place-after you clean it. You'll be amazed how much dirt settles in that box but don't be fooled, there's still enough fine dirt to clog your air cleaner element. Kira
Old Mar 25, 2010 | 05:04 PM
Thanks for the reply. I was eyeing that air cleaner box up today wondering how it comes out. I did see exactly what you are talking about!
Thanks again!
Old Mar 26, 2010 | 08:23 PM
Lights are on. I had to do the headlight on the other side at the same time. Good advice, thanks!
Old Mar 26, 2010 | 10:23 PM
checksix's Avatar
When I removed my air box, I took a small 12 point socket on a long extension that fit over the flaired split fasteners. Picking the right size when pushed down on them it compresses the fitting, then pull up on the box base and it's free. Pushing down and pulling up at the same time is a bit of a trick, but when the split plastic holders are compressed removal is easy.
Jerry
davej
Apr 22, 2011 08:47 AM
mifisher01
May 24, 2010 08:12 PM
crosby1
Apr 15, 2010 08:17 PM
rfmommy
Jun 26, 2009 07:54 AM
bobschwind
Apr 8, 2009 09:25 PM
