Turn Signal Bulb Failure Message, but bulb okay
Old Apr 19, 2011 | 01:59 PM
davej's Avatar
Default Turn Signal Bulb Failure Message, but bulb okay
I have a 2002 S60. Recently I've started having a problem with the turn signals. Often, when I turn on the right turn signal, the turn indicator in the dashboard is flashing faster than normal, and I get a message saying that the right turn signal bulb is gone. However, when I check the lights, all 3 turn signal lights (front, back and passenger door) are working okay, although flashing at an increased frequency. This problem doesn't happen everytime I use the turn signal. This problem also happens occasionally with the left turn signal, but it seems more rare with the left turn signal. Does anybody have an idea what the problem is, and how to fix it.
Old Apr 19, 2011 | 05:22 PM
fcpgroton's Avatar
Former Sponsor
I bet the turn signal relay is going bad.
Old Apr 19, 2011 | 05:42 PM
MattyXXL's Avatar
Do you have LED bulbs installed?
If not could be a bad connection in the turn sig switch, loose bulb or as FCP said a flasher relay..
Old Apr 21, 2011 | 01:52 AM
snow2011's Avatar
I aggree !
Old Apr 22, 2011 | 08:47 AM
ibanez958's Avatar
check your turn signal bulb socket, switch then with the other side
mark1209
Nov 6, 2013 10:04 PM
jasonthaynes
Dec 2, 2012 05:32 PM
pmvictory
Jan 24, 2011 08:06 PM
mkacer
Jul 8, 2009 11:37 PM
liamhenryf
May 2, 2009 01:12 PM
