tyre presure
Old Jul 11, 2008 | 10:18 AM
oldgit63's Avatar
Default tyre presure
[:-]It is me again looking in the petrol flap for tyre pressure so it tells me the psi for saloon but not for estate v70 2001 tyre size 215x55x16 93h can anyone provide me with correct psi please? regards Trev.
Old Jul 11, 2008 | 10:21 AM
S70driver's Avatar
Default RE: tyre presure
Probably anywhere from 36-40 PSI.
Old Jul 11, 2008 | 11:09 PM
samadkins29's Avatar
are you telling me their is no max psi written on your tire????
Old Jul 12, 2008 | 04:31 AM
oldgit63's Avatar
HI Smadkins29 re to your reply the thing being for the first instance you dont know if the tyres are volvo fitment so to go of max or min psi on a tyre that was not a volvo fit wont do .The tyre fitted at manufacture is Pirellip6000 the psi that volvo recomend for the car from new is what i am after . Regards Trev
Old Jul 12, 2008 | 04:35 AM
oldgit63's Avatar
Thank you S70 DRIVER i wil try your 36psi and tyry up to 40 psi and let you know how it goes .Regards Trev.
Old Jul 12, 2008 | 04:51 AM
rules's Avatar
Here you go git
Old Jul 12, 2008 | 05:26 AM
oldgit63's Avatar
Rules from Cape Town South Africa this fuel cap is just the same as mine but it is void of the estate or station waggon tyre pressures it is only for saloon or sedan all other volvos i have owned gave estate psi regards Trev. ps nice to hear from you have a nice day.
Old Jul 12, 2008 | 06:32 AM
rules's Avatar
The sticker says "V70 Turbo". So these specs are for the Station Wagon/Estate, hence the "V" and I'm sure that Volvo wouldn't just stick any random specs on the car. If you aren't using the original spec tires, then I suggest checking with the manufacturers for the correct pressure.
Cheers.
dkchandler
Sep 26, 2016 01:06 PM
bitnissen
Sep 21, 2009 01:06 PM
Domm
Feb 14, 2009 11:09 AM
matty052
Mar 18, 2005 10:35 AM
