V70 Multiple issues
Old Jul 11, 2008 | 06:57 PM
lrizzell's Avatar
Default V70 Multiple issues
Hi everyone!
I can't find the chime for the key or seatbelt. There is no chime when key is ignition and door is open.
How do I get to the instrument lamps in the shift console, (Automatic)
Driver side sun visor light does not work. Not bad bulbs.
Hope to hear back soon!
Old Jul 12, 2008 | 07:24 AM
Default RE: V70 Multiple issues
What year is the car?
Old Jul 12, 2008 | 07:26 AM
rules's Avatar
Hello
I think the V70 only chimes for the seatbelt.
As far as I remember, the "lights" in the shift console are actually LEDs, so I doubt there is something wrong with them. Maby just not getting power? wiring plugs? fuses? Anyway, you remove the pen holder "panel" at the bottom of the center console and you will see 2 clips which will release the shift console. Then there is a couple of clips at the bottom which need to be released to get the main unit out. It's a bit of a fiddly job.
If bulb is good, check fuses and if thats good check wiring and/or switch mechanism.
Hope this helps a bit
coolrider
Apr 21, 2014 10:09 AM
Volvo850Rookie
Mar 17, 2014 09:30 PM
Trisum
Dec 13, 2013 11:34 AM
djwkndev
Sep 9, 2013 09:26 AM
jamesp
Sep 2, 2013 05:12 PM
