V70 Check Engine Light
Old Mar 3, 2008 | 08:54 PM
volvojag's Avatar
Default V70 Check Engine Light
Got the Check Engine Light. Still runs like a champ. Autozone read the code as P0410, which is a secondary air injection system fault.
What is this? How much is it gonna cost me!?
Thanks!
Old Mar 3, 2008 | 08:58 PM
Default RE: V70 Check Engine Light
It is expensive to fix.
The Air pump directs hot air from the exhaust when the car is cold into the air filter box to help the car warm up quicker.
The pump is quite pricey. I believe between $300.00 to $400.00.
Plus you should replace the relay and Valve as well.
Old Mar 3, 2008 | 09:02 PM
volvojag's Avatar
Tech,
Thanks for the quick response! Performance is fine. Will not fixing this cause other problems?
Old Mar 3, 2008 | 09:23 PM
It will mainly keep the check engine light on all the time.
Old Mar 4, 2008 | 12:02 PM
JimKW's Avatar
I bought an air pump and relay used from Erie Auto Parts. That was about 2.5 years ago and my CEL has not come back on. I think they even give a lifetime warranty so if it goes bad they will send you another one.
Old Mar 5, 2008 | 11:29 PM
volvojag's Avatar
Tech and Jim,
Thanks for the replies...I appreciate it!
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
