V70 engine stutter?
Old Oct 23, 2007 | 11:47 PM
lemans24's Avatar
Default V70 engine stutter?
I have a 1998 V70 GLT. Here's the problem...Upon taking off from a stop, there is a hesitation or stuttering (i.e.: a feeling as if the car doesn't want to accelerate) until either I momentarily step off the gas pedal (accelerator)or achieve 30 mph and above. My guess would be either fuel injector(s) or fuel pump. Anyone experience this problem? Any feedback would greatly be appreciated.
Old Oct 24, 2007 | 05:40 PM
Default RE: V70 engine stutter?
Last tune up?
Any check engine light?
Old Oct 31, 2007 | 10:16 PM
Volvocars's Avatar
Check your plugs
Old Jul 25, 2008 | 09:13 AM
simon37's Avatar
I have similar problem with my 1996 V70. If I try to accelerate (in any gear including reverse) engine will stutter and cut out unless I ease back. When moving forward from standstill, I need to slowly get the revs up quite high before releasing the clutch, otherwise again it will stutter and die.
There is a lambda light on, but I thought the problem associated with that had been fixed but that the light just remained.
Any help would be appreciated.
Simon
Old Jul 26, 2008 | 08:45 AM
mr maraki's Avatar
Sounds like your throttle position sensor, try unplugging it.
Old Jul 26, 2008 | 03:02 PM
simon37's Avatar
thanks.
will have this looked at. Simon
jbyszewski
Mar 24, 2020 03:33 PM
elav
Jun 22, 2011 09:31 AM
mgurzenski
Jun 18, 2009 07:15 PM
applcor
Jan 17, 2009 10:16 PM
rousha
Jul 19, 2005 05:18 PM
