V70 Fuel Filter
Old Nov 5, 2008 | 07:37 PM
mandof5's Avatar
Default V70 Fuel Filter
Hey everyone. I have a 2004 Volvo V70 and I am trying to change the fuel filter and I looked everywhere and I can't find it. I was told it is on the passenger side by the rear axle but I didn't find it???
Old Nov 5, 2008 | 11:46 PM
checksix's Avatar
Default RE: V70 Fuel Filter
That's where mine was on my 01 V70 T5. If you have the replacement you should be able to easily recognize it. Extreamly easy to change. BTW I changed mine at 90K miles, and then cut it open to see how bad it was. There was no contamination visible to my eye. That's not to say how your's would be, as I don't know where you get your gas. I use only Chevron. With the new plastic tanks the build up of junk in the tank has been significantly reduced.
Jerry
Old Nov 6, 2008 | 12:39 AM
mandof5's Avatar
I called the dealership and they told me that the fuel filter is by the gas tank by the rear axle. I had my buddy take a look, who has been a mechanic for a few years now, and he couldn't even find it!?!?
Old Nov 6, 2008 | 12:44 AM
v70 2.4t's Avatar
I think i read somewhere that 2004- had a in tank fuel filter...
I may be wrong but i think its in the tank..
good luck
v70 2.4t
Old Nov 6, 2008 | 10:20 PM
checksix's Avatar
You did not post the exact model you are looking for, but in looking up a fuel filter for a V70 2004, I got a part that looks very similar to mine, but did note it was for 2001 and up where my model was a 2001. Since it had such a similar look, I don't buy into the "in gas tank" theory. Take a look at this link and perhaps it will help you find what you are looking for.
http://www.fcpgroton.com/category-ex...83/by_year/54/
Jerry
Old Nov 7, 2008 | 07:29 AM
If you have an aluminum tank then you do not have an external fuel filter.
They put them in the tank(Crappy design they only used for 1 to 2 years.
Old Nov 10, 2008 | 08:20 PM
Alltwin's Avatar
Hi,[/align][/align]I just recently replaced mine, it's located at the rear (just in front of the rear wheel) behind the passengers seat.[/align]Just push the two brackets clips inside on the tube clip and pull the tube from it with a little bit of force, please put a pan underneath it to avoid gasoline spillage.[/align][/align]The filter will cost you approx $29.[/align][/align]Good Luck[/align][/align]Alltwin[/align]
timoc663
Aug 14, 2016 05:35 PM
AMAP58
Oct 29, 2013 07:03 AM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
AnEskimo
May 15, 2011 12:32 AM
