V70 FWD 2000 klunking noise
I am a new owner, but have built and worked on muscle cars for 30 years.....
This noise is not a body panel or hose... it sounds like a shock mount or motor mount type noise. but i have inspected both ... front and back... nothing seems out of whack. now i know I could break out the air ratchet and go from front to back checking I tightening everything and I will eventually find it, but I thought checking here might point me in an easier direction.... and there are more than one clunk both front and in the rear... car is exceptionally clean and well maintained with 105,000 miles on it.
Brian
Brian
Did you check the rubber spring seats up front? The easiest way to check is to put a wrench on the top center strut nut. If the nut spins it is most likely bad.
Also check the sway bar end links for play. With the car in the air pull on the sway bar and feel for a click.
For the rear the upper shock mount or the shock might be bad.
= The front spring seats are good
= when you say car in the air... do you mean on jack stands or a full on lift?
And thanks for the leads!!
where do I get new bump stops??
B
The whole shock doesn't need to come out, just the bottom nut and compress the spring to remove the bottom of the shock. no big deal....
