V70 immobilizer location
Old 12-04-2009 | 11:22 PM
ddrewyor's Avatar
Default V70 immobilizer location
Does anyone know where the immobilizer box on a 1999 V70 GLT is located? Also, what does it look like? I had the stalling upon start issue and the key flip worked for awhile, but the failure began happening more often so I tried all three keys with the samme result. Based on what I read here, I replaced the antenna ring tonight and it did not have any issue after several trips and multiple starts. I am a bit pessimistic on this one as it was intermittent so if that does not do it, then the immobilizer it is. Yep, I know, new keys and a trip to the dealership for programming. Thanks in advance
Dave
________
FIX PS3
Old 12-15-2009 | 10:43 AM
ddrewyor's Avatar
Default Update on immobilizer issue
So far so good! It's been almost two weeks and the car has been starting every time since I replaced the antenna ring. The problem seemed worse when it was cold and wet - so the real test has been the past few days here in MI. I am keeping my fingers crossed. This site really helped out solving the issue and keeping cash in my pocket. The antenna ring was $46 shipped and the install was quick and painless. I popped the top of the steering shroud and then removed the lower shroud screws (3). The ring just unplugged and slid off.
Dave
________
Free Kohls Gift Card
Old 11-06-2010 | 09:19 PM
kennyrocker's Avatar
Hi Dave, I got excet same car and the same problem as you did. I m gona try your solustion out, thx for sharing.
Old 11-07-2010 | 10:39 PM
ddrewyor's Avatar
Kennyrocker,
I have not had a problem since I replaced the ring. I hope that is all that is wrong with your car! Let me know how you fare.
Dave
________
LovelyWendie99
Old 11-10-2010 | 12:11 AM
Dave,
I just replaced mine, it starts right away. no hesitation with both of my keys. I think I got it fixed. Cost 65 bugs to get the antena ring from volvo. I heard that ring is meant to be fail. I hope they last tho. Cheers!
Kennyrocker
KREID
06-23-2021 03:37 PM
VolvoV701987
10-04-2010 07:17 PM
yousefkali32825
09-23-2006 08:31 PM
benbtj
04-09-2006 05:55 PM
gmyoryi
11-19-2004 10:49 AM
