V70 Signal lights
Are you sure the outside lights dont flash when you flick the switch? it could just be the bulb burned out in the cluster. Super easy fix, pull off the cluster surround, theres 4 t20 Torx screws holding the cluster in. Disconnect the green connector in the rear, and you can twist out the bulbs for replacement.
Jayrivera
02-26-2012 09:57 PM
