V70 Vibrations
Old Jan 12, 2008 | 06:14 PM
valu's Avatar
Default V70 Vibrations
I have recently purchased a 2005 V70 2.4L and Iexperience some vibrations coming to the steering wheel and driver seat while in idle which it is amplified indrive mode. It feels like the powertrain isolation (engine mounts) is faulty.I am wondering if anybodycan give some idea where to check for the root cause.
Thanks,
Valu
Old Jan 12, 2008 | 07:14 PM
Eric J's Avatar
Default RE: V70 Vibrations
Welcome to the Forum Val.
Do you have an cyclical or eratic idle or is it more of a steady shake ?
Old Jan 12, 2008 | 10:02 PM
valu's Avatar
It is a steady vibration. It is getting worse when the engine is warmed up. The vibration amplitude seemstoo high.
Old Jan 12, 2008 | 10:23 PM
Eric J's Avatar
Sorry for the absence, I was watching the Patriots game.
What RPM is the idle? Maybe to low.
Does it clunk, going from forward to reverse back to forward?
Do you feel the enginelift and dropif you givea littlegas with the brake on, in forward or reverse? Motor mount.
Old Jan 13, 2008 | 12:49 AM
Rickc10ny's Avatar
These 5 cylinder engines don't idle like many other cars. They vibrate a little ( or buzz as it feels to me) Since you bought it recently it should be under warranty, Take it back to the dealer for them to check out If the dealer says the mounts and bushings are ok ,tell the dealer to look closely at the exhaust system, Someone may have run over a curb and or other object in the road which can bend the exhaust system to where it contacts the chassis and creates vibration.
Old Jan 13, 2008 | 01:36 PM
Eric J's Avatar
Good points Rick.
Old Jan 15, 2008 | 06:23 AM
valu's Avatar
Thank you for your replies.
The weird think about this vibration is that is showing up after 20-25 minutes of driving and is affecting not only the idle but all the RPM range up to about 2,000. The ride is simply becoming very rough. I wll go to the dealer and ask to check all the rubber elements and the exhaust as recommended in this forum.
Thanks,
Valu
wonderguy
2001-2013 model year V70
Mar 28, 2012 06:53 PM
S70ismyfriend
Mar 22, 2007 02:00 AM
flamejet
Sep 10, 2006 02:29 AM
Jutboy244
Apr 26, 2006 12:49 AM
BlackDiamondBound
Aug 4, 2005 01:28 AM
