Volvo V70 2.4 D5 2004 front and rear window washer not spraying
I have a problem. Front and rear window washer not spraying, but headlamp sprayer does work. Both front and rear stopped working at the same time. I have nothing else to say about this problem.
check the tubing from the pump to the jets or run the pump looking for leaks. when this happened to my S40, turned out there's a T-connector on the passenger side inner fender that disconnected. Trimmed the hose, reconnected, been good ever since.
