Rear washer pump question
Old Nov 18, 2013 | 09:40 PM
Phil 850's Avatar
Default Rear washer pump question
My rear washer pump hoses are caped off so can some one tell me which connection on the pump is the inlet? I am fairly sure it is the one on the bottom and the out let is to the side.
Old Nov 18, 2013 | 10:43 PM
Huh? Inlet? The pump plugs into the bottle, there is a vent line, the other 2 are outlets.
Old Nov 18, 2013 | 11:22 PM
Phil 850's Avatar
The pump for the rear window washer does not plug into the bottle but has two hoses connected to it. One is the inlet side and one goes to the rear window sprayer. This is the pump that is mounted under the front of the car.
Old Nov 19, 2013 | 02:33 AM
scutyde's Avatar
The bottom connector is the inlet, side is outlet. Check the pump if it runs, Volvo chose a poor place for it there and it gets a lot of moisture and dirt ...
Cristian
who fitted in his 850 the V70 washer system with spray nozzles https://www.dropbox.com/s/zpyuoxhdyf...aschanlage.pdf
fixitpimp
Jan 11, 2009 10:17 AM
darkdelta
Nov 6, 2008 07:36 AM
adammiller
Mar 3, 2008 02:48 AM
mason_200
Apr 18, 2007 08:21 PM
info2x
Feb 4, 2006 04:45 AM
