Volvo v70 parts help
Old Aug 13, 2011 | 10:34 PM
ollieollie's Avatar
Default Volvo v70 parts help
Hi All. I am a young, looking at fixing a few things. it is a 1998 volvo v70 20V.
I would like to know if these parts will fit my car
Volvo Performance Brake Kit 288MM (Zimmermann Cross Drilled) - 850ULTKIT
Volvo Performance Brake Kit 288MM (Zimmermann Cross Drilled) - 850ULTKIT | FCPEuro.com
Volvo Control Arms Suspension Kit Shocks Struts Mounts (850 V70 S70) - OEM 850KIT10FR
Volvo Control Arms Suspension Kit Shocks Struts Mounts (850 V70 S70) - OEM 850KIT10FR | FCPEuro.com
I am also happy for anyone to advise me off better parts they wish to recomend. Basically i am getting these two kits because they seem to cover everything? ie all suspesnsion and all of brakes
cheers
Old Aug 25, 2011 | 06:02 AM
ollieollie's Avatar
Default any help?
can anyone help?
Old Aug 25, 2011 | 06:38 AM
Georgeandkira's Avatar
Default Too broad a question
Hello, Obviously you did your research. The people at fcp can tell you the fitment range. You mention doing "all suspension and all of brakes"; you're not. You're not addressing calipers, brake lines, tie rod ends, sway bar end links or anything in the rear of the car. It's not that you have to, it's that you're not buying any huge parts order or converting to any parts which are special. All you're doing is some maintenance on a 12 year old car. Get started with these "common" replacement parts and see and feel how much better your car drives and stops. There might be parts for YOUR car and YOUR SITUATION which would be slightly better or worse for slightly more or less money-but there's no way anybody can know that. Check other parts for wear as you install these. Kira
T77911S
Jun 28, 2018 02:18 PM
JawdB
Jun 10, 2015 09:47 PM
Iamdagerman
Mar 4, 2013 12:27 PM
TacklaNHL
Jul 29, 2012 11:20 PM
andrew123
Canada, Over Seas & Elsewhere
Jan 9, 2011 05:09 PM
