Weird idle
Old Jun 22, 2010 | 09:50 PM
HH1907's Avatar
Unhappy Weird idle
Hi again. I've got a problem with the engine idling. It just starting doing this tonight. I turned the car on, the RPM went down below 1000 to its normal idling range, and the engine started going voo voo voo voo voo voo voo voo voo voo the lights only in the interior started dimming on and off everytime the engine went voo voo voo. Turned the A/C on the RPM rose a little bit and the engine started idling fine, turned the A/C off and it went back to dimming lights and voo voo voo voo voo and one time after I turned the A/C off the engine actually shut off. Can someone help me please? Thank You.
Old Jun 22, 2010 | 09:57 PM
I would try cleaning the throttle body and see if that fixes it.
Old Jun 22, 2010 | 09:59 PM
HH1907's Avatar
Hey, thank you for replying tech. Where is the throttle body located? How should I clean it? 2001 Volvo V70 T5
Old Jun 22, 2010 | 10:04 PM
On yours it is located under the intake manifold. It would be best to remove it and clean it then reinstall it. But you will need to get a new gasket. Volvo and some people say you need a special cleaner to do it. But I have been using Carb and brake clean for years to clean them.
Old Jun 22, 2010 | 10:07 PM
HH1907's Avatar
ok. Will try that. Thanks for your help. I'll keep you updated.
Old Jun 23, 2010 | 01:27 PM
HH1907's Avatar
Hey guys. I didn't do anything to the car yet. I filmed three videos. The first one shows how the engine sounds, the second shows how the lights flicker, and the third one shows how the RPM drops after giving gas. I would be very happy if anyone can view them and tell me if things are normal with this car. P.S. when it idles in park I feel like I'm having a pulsating back massage.
1. http://www.youtube.com/watch?v=yhh_9AnpGpM
2. http://www.youtube.com/watch?v=F-BHbnOGeMQ
3. http://www.youtube.com/watch?v=Fg-JwAfgwYw
Old Jun 23, 2010 | 03:28 PM
HH1907's Avatar
By the way, Tech. I found the throttle body but how can I remove it? Do I need to remove the intake manifold? And once I remove it, how should I clean it or what part of it should I clean?
Old Jun 23, 2010 | 04:22 PM
Bobec's Avatar
Here's a video that shows cleaning.
http://www.youtube.com/watch?v=8Zaxtm-hdyo
I also worked a bit of thin synthetic oil around the shaft where it goes into the body with a Qtip. There are o-rings in there that might create drag on the shaft
Old Jun 23, 2010 | 09:39 PM
That video will work for yours as well. Yours is slightly different but same thing overall.
Old Jun 24, 2010 | 01:08 PM
HH1907's Avatar
Thank you so much for your help Tech and Bobec. I have to try this at my cousin's shop soon. I'll keep you updated. Thanks guys. This car drives me crazy sometimes but I still love it, 228,000 miles and still running strong.
Old Jun 26, 2010 | 04:11 AM
HH1907's Avatar
UPDATE 6/26/2010 5:00 A.M.
Me and my father just finished working on the car. Cleaned the ETM. We've been working on it since 12:00 A.M. took us 5 hours but it was worth it, the car is idling like its brand new. Hopefully it stays this way. Thank you very much Tech and Bobec.
2001 V70 228,000 miles
Old Jun 26, 2010 | 07:56 AM
Glad all went well!
swiftjustice44
Oct 25, 2012 06:32 AM
Keilah
Sep 16, 2009 09:35 AM
BoomeR
Sep 6, 2009 03:32 PM
Earwig225
Dec 12, 2008 06:21 PM
TacklaNHL
Feb 4, 2008 10:00 PM
