Volvo XC40 Volvo XC40 compact crossover forum discussion, how-to guides, and technical help.
Trying to update maps via USB
Old Oct 27, 2022 | 10:48 AM
MyXC40's Avatar
Angry Trying to update maps via USB
Hello.
I own a 2021 XC40 T5 and I'm attempting to update my nav maps via a USB thumb drive, but the vehicle is not reading the USB while it's running.
I followed the instructions below from their website:
Download the Latest Maps (custhelp.com)The map must be downloaded to an empty 64 GB USB memory stick formatted with exFAT or NTFS (if downloading the full North American map) or 32 GB memory stick (if downloading the Regional Maps) formatted with FAT32.
Base Map:
Download the North America map upgrades here for Windows
Download the North America map upgrades here for MAC
After you select the appropriate link for your operating system, please select "Run" from the pop-up menu, select "New Download" and select USB.
Anyone out there having issues with their vehicle not reading the USB? I've formatted in exFAT and NTFS - nothing works.
Appreciate the help!
Old Nov 16, 2022 | 01:38 PM
adeeljaffri's Avatar
May I know if you were able to find the solution...Did USB stick with FAT32 format worked?
i have similar issue on my 2016 XC90 plugin hybrid
Old Nov 16, 2022 | 01:52 PM
MyXC40's Avatar
It did not work for me as my USB was 128gb (too big to format to FAT32). The workaround was using my iPhone hotspot/bluetooth to download the maps while the vehicle was in use. Every time I used the vehicle, I turned on my hotspot and the download/installation would resume. Just keep in mind this will take an hour or so.
Old Nov 16, 2022 | 02:08 PM
Well, I tried that option but it is saying that upgrade is more then 1gB and can't be downloaded directly...
Old Nov 21, 2022 | 06:22 AM
jmcamp54's Avatar
Default XC40 Map updates
Originally Posted by MyXC40
Hello.
Base Map:
  • I just updated mine this past Friday. I formatted the 64 GB USB drive pen drive NTFS and then uploaded it to my 2021 XC40 . Did you make sure that you went through the complete download and the verification of the pen drive after the download? (As ignorant as this may sound) Are you making sure that you inserted the pen drive in the USB port with the white outline around it? If you’ve done that I hope someone else has an idea on why it won’t load.
Old Nov 22, 2022 | 10:13 AM
MyXC40's Avatar
I went through the complete d/l & verification after the download and inserted into the USB (white outline). I wonder if it's possible my USB is too large (128gb)? I may be worth a shot to use a 64gb USB to test.
Pretorien
Aug 7, 2023 06:57 AM
Jimtel
May 6, 2022 06:08 PM
crcarson
Jan 26, 2020 03:14 PM
Nancy N. Palmquist
Aug 13, 2019 12:27 PM
Pretorien
Jan 6, 2019 05:26 PM
