Xc40 12 volt battery charge fault
I have a 2020 xc40 . About 2 months ago the fault message 12 volt battery charge fault came up. I tested the output of alternator and it was low at between 11.2 -11.8 when running . I booked it in with dealer and because there was a 2 week delay it cleared up before it went in . I explained what had happened and the dealer put it on computer and couldn’t find a problem . I had a volt checker that you can plug into 12 v charging point so the output can be monitored while driving and the voltage does bounce around a bit between 11-13.8 volts which I don’t think is right . The dealer told me this wasn’t accurate which I do t agree with so I left with a car that wasn’t fixed and today the message had come up again and the volt checker was reading as low as 10.4 . I know this car is gonna break down as some point this will be the only way the useless mechanics at Volvo will be able to fix it as they can only fix what the computer tells them . Has anyone else had this problem.
