2010 XC60 - AC works for only 10 min
Old Oct 29, 2023 | 11:59 AM
Riklong's Avatar
Default 2010 XC60 - AC works for only 10 min
Hi. My AC works for only about 10 min (very cold). Have to leave car off for few hours then works for another 10 min.
Old Oct 29, 2023 | 03:36 PM
If you have the 6 cyl engine - That engine has a variable displacement compressor. Displacement is controlled by a valve - that usually has the opposite problem, as in takes a longer time to cool. A good first step would be to measure the AC pressures under both conditions.
Old Oct 31, 2023 | 01:47 PM
not sure if its the same for the newer compressor designs but on the older models, this could be caused by the compressor clutch gap being too wide (again older models, .3mm is optimal, when it gets over .8mm it will start to slip, overheat then fail).. You may want to google for specs on your model/year to see if that's also a common issue and whether the clutch can be reshimmed. (sorry never owned a Volvo as new as a 2010 lol )
Old Nov 6, 2023 | 08:43 PM
Riklong's Avatar
Default Pressure
When it's works pressure is around 40 PSI, when it's stopped is around 100 PSI
Old Nov 6, 2023 | 08:46 PM
Riklong's Avatar
When it's works pressure is around 40 PSI, when it's stopped is around 100 PSI.
Its 6 cyl
Flashscuba
Oct 18, 2023 12:49 PM
itskip
Apr 2, 2022 11:07 PM
Talon747
Aug 19, 2021 04:09 PM
Chris Gordon
Aug 31, 2020 04:27 AM
lancecx
Oct 20, 2012 10:38 PM
