2015 xc60 d4 which alarm siren do I have?
Old Apr 19, 2022 | 08:15 AM
jim#'s Avatar
Default 2015 xc60 d4 which alarm siren do I have?
Getting the alarm system service required fault.
I understand its a battery replacement needed and the unit can be found under the front wheel arch and the rivets need drilling out and replacing.
I would like to be prepared prior to doing the work so would like to know if the unit in mine would be the type im seeing on the youtube vids ie:black horn and white back that needs cutting apart at the seem, And what battery to replace it with? I have ordered some rivets 21mmx4mm.
Regards Jim
Old May 28, 2023 | 01:16 AM
Manka's Avatar
Regards Jim
Hey Jim, I'm in a similar position. Did you figure out which one you needed? Also where did you get your rivets from...
Finally is this easy to do yourself with a jack? Thanks
duckpuddle
Jan 26, 2022 08:42 AM
Jano3000
Dec 13, 2021 01:29 PM
SteveMoVa
Sep 24, 2015 12:04 PM
nnj
Jan 11, 2015 10:38 AM
2002t/a
May 12, 2014 03:08 PM
