2023 proximity sensor
Old Jan 26, 2024 | 08:42 AM
stargazer1201's Avatar
Default 2023 proximity sensor
Hello, Does anyone know how I can turn off the proximity in the 2023 XC60 so that it doesn't go crazy when I'm driving it through the car wash?
Old Jan 26, 2024 | 11:11 AM
jacko15's Avatar
https://www.volvocars.com/lb/support...a801514d5309ac
Deactivation is the same in the XC60.
Old Jan 26, 2024 | 12:43 PM
I found the answer to my question
Automatic car washes
Updated 2023-11-17
It is important to prepare the vehicle before washing it in an automatic car wash. Carefully follow the instructions for vehicle handling before and during the car wash.Automatic car washes can be a fast and easy way to clean the vehicle, but they do not reach all the parts of the vehicle that need regular cleaning. Volvo recommends supplementing automatic car washing with hand-washing.
Note
Avoid washing a brand new vehicle in automatic car washes for the first few months after it leaves the factory. This will allow the paintwork to fully set.
Preparations before washing
In automatic car washes in which the vehicle is pulled through the car wash, it is important to switch off functions that prevent the vehicle from rolling freely.
  • Secure or remove protruding exterior parts such as retrofitted auxiliary lights, antennas, etc.
  • Make sure that the automatic rain sensor function is switched off. The windshield wipers must be switched off throughout the car wash to avoid the risk of damage.
  • Use the button in the tunnel console to turn off automatic brake when stationary.
  • Choose the parking camera view in the center display and deactivate the Park Assist sensors and automatic brake while backing up. They may be reactivated if the vehicle is restarted, and must then be deactivated again.
During the car wash
Important
Keep the vehicle's windows, doors, panoramic roof* and tailgate closed throughout the car wash.
If the vehicle is equipped with keyless locking and unlocking*:
Take out the key and place it in the open in the front section of the vehicle during the car wash. This minimizes the risk of unintentionally pressing the button that opens the tailgate, or of the key being incorrectly detected outside of the vehicle.
Keep your seat belt buckled for the entire car wash.
Drive into the car wash and stop at the designated place.
Put the gear selector in N.
Turn the start **** in the tunnel console clockwise and hold it for a few seconds to put the vehicle in ignition mode 0.
The motor is switched off, while the vehicle can roll freely.
The vehicle goes through the automatic car wash.
Don't forget to reset the adjustments made before the car wash.
After the car wash
Depress the brake pedal lightly for a short time while driving after the brake pads have been exposed to moisture. The friction will heat up the brakes so that they will dry more quickly, reducing the risk of corrosion.
bertilak
Apr 12, 2023 06:38 PM
colin313
Nov 30, 2022 09:37 AM
imaginarydave
Feb 10, 2022 12:53 PM
Ewendt7
Nov 2, 2021 02:51 PM
Alextreme093
Jun 5, 2018 11:17 AM
