Cracked engine cap locking piece and one dropped into the engine.
Old Sep 18, 2022 | 02:29 PM
fiedel's Avatar
Default Cracked engine cap locking piece and one dropped into the engine.
I just cracked the locking piece of the engine oil filler cap (part # 30677911) by over turning it. I was able to pick out two big pieces but one small piece (see the pictures) is small missing, and I couldn't see it. It seems to be plastic. What should I do now?
Old Sep 19, 2022 | 01:51 PM
Willd's Avatar
Nothing much other than an oil change, hopefully it will be washed out with the oil. I wouldn't be overly concerned, a small piece of plastic is no match for the forces found in the crankcase.
Old Sep 19, 2022 | 04:51 PM
fiedel's Avatar
Just drained the oil before cracking the cap. Maybe should do flush the engine?
Old Sep 20, 2022 | 10:01 AM
I'd try hooking up a small hose to a shop vac and inserting it in the fill hole - you may get lucky and grab a piece if its still sitting up top. Otherwise as Willd noted, it may find its way down one of the oil galleys do the oil pan and you may see it come out. You said you just filled the oil so it should be clean enough to see any bits and you can throw it back in (assuming you use a clean drain pan (or buy a foil "turkey" pan to use.) The only other thing would be to remove the oil pan to see if its down there and to make sure its not caught in the pick up which could lower your oil pressure.
A true story: years ago a buddy built a high performance 454 with a very radical cam. ran the car hard one day and suddenly the oil pressure light came on. We dropped the oil pan and found that all the valve seals got mashed, found there way into the pan and clogged the pick up. Wound up redoing the heads, cleaned out the pick up and pan and the engine was good to go with no further issues.
brangerii
Dec 12, 2018 11:40 AM
habbyguy
Aug 11, 2018 05:40 PM
liweih21
May 27, 2013 06:51 PM
re100005
Apr 19, 2011 12:41 AM
DON
Penta
Jul 29, 2007 12:01 PM
