Engine Coolant Recovery Tank Hose
Problem fixed, had to break away the connection ferrule to get it to release. Stripped out the grey connection internal components and replaced fitting O ring with a larger section item after applying lubrication grease. Pushed the fitting back onto connection spigot and secured with a cable tie, pressure tested, no more leaks. Saved approx $A40 applying this fix. Maybe Volvo knows the O ring sizing on 31319051 is suspect.
samjaynz
02-12-2017 11:24 PM
