Coolant Leak V70 T5
Old Apr 7, 2018 | 08:35 PM
V7oT5's Avatar
Default Coolant Leak V70 T5
My coolant tank is empty. Whenever I fill the tank, ALL of the coolant in the tank leaks out within several minutes.
I removed the tank and checked it and it is good to go.
The hose is dry that connects the tank with the next flow area and the coolant is actually draining from the front of the car... see the pic
V70•T5 Leaking coolant as I am adding the coolant (before even starting the car).
I removed the tank and tank is in good shape plus hose connections from the coolant tank are dry. Hose connection to the next clamp is also dry -
The leak is in the front of my car...
see the pic.
Any ideas? hose? pump?
The coolant tank empties within minutes of refilling.
Old Apr 8, 2018 | 02:45 PM
tony1963's Avatar
The leak is directly under the radiator drain and also the lower radiator hose. The only way to find this is to support the car on jack stands or a lift and remove the lower paneling to inspect the hardware.
Magnusson
Jun 13, 2016 05:08 AM
willsern
2001-2013 model year V70
Mar 4, 2016 01:49 PM
mike.velez
Sep 10, 2014 07:53 PM
beejay
1998-2000 model year V70
Jun 29, 2012 07:53 PM
snsrgy611
Apr 6, 2009 07:08 PM
