Fuel filling issue
Old Jan 22, 2018 | 04:22 PM
Michael Phelon's Avatar
Cool Fuel filling issue
When trying to fill the car with fuel the pump automatically shuts off as if the car is already filled you hear a gurgling noise and repeat the process but it won't let you fill the car but ever so slowly. The dealership said I need to replace the fuel filler tube which is $250 in parts for a total repair of $1,300. I don't believe this is the issue but if anybody has experience please chime in.
Old Jan 30, 2018 | 07:59 PM
Oakplank's Avatar
I believe that there should be a vent/overflow tube that may be blocked. When you pump gas in your tank, you are replacing the air with fuel. The air escapes through a vent. If the vent is blocked, the air can not escape and will therefore block the gas from going in. You can’t have gas and air occupying the same space at the same time.
Old Apr 11, 2022 | 02:04 PM
Bob4's Avatar
Sorry wrong thread.
Old Jul 22, 2022 | 02:12 AM
Conradv2's Avatar
RE-igniting this thread , suddenly my V50 is doing exactly the same. I thought it might be the specific fuel pump but it's every gas station I go to so rules that out. I also wondered if the fuel had changed , additives etc , it looks like foam on the top? Driving me nuts, from empty it is taking 18 minutes to fill , sadly I timed it (might as well go electric )
@Michael Phelon , did you find a reason or solution ?
Cheers
Conrad
Old Jul 26, 2022 | 11:27 AM
meghan0607@msn.com's Avatar
I just took my xc90 to the Volvo service place bc my check engine light was on. They narrowed it down to the fuel filler neck. I didn’t really think much of it but every time I filled the tank, it would stop multiple times and would sometimes spill out. So that may be the same problem as yours. 🤷🏻‍♀️ My car is still under warranty so it was covered. Not sure how much it would cost out of warranty. Hope that helps
Cheers
Conrad
timothyha22
Jan 23, 2018 01:32 PM
rockman413
Feb 27, 2015 06:12 PM
Daumants
1998-2000 model year XC70
Jul 31, 2013 11:56 AM
Dr. J
Jun 5, 2011 10:54 PM
nhutnik
Sep 23, 2008 12:51 PM
