putting gas into cS-80
Old Sep 17, 2008 | 12:50 PM
nhutnik's Avatar
Default putting gas into cS-80
I am unable to put gas into my 2000 S80 without it backing up. The only way fuel will enter is at a very slow flow; at full flow it backs up and over flows onto the ground. Anyone have any ideas?
Old Sep 17, 2008 | 04:26 PM
NasS80Tbo's Avatar
Default RE: putting gas into cS-80
I too have a 00 s80 T, and for the past 2 months I have been having the same problem. It was so random that I though it was the pump at the station. After going to another station I realized that I was having the same issue. The pump either shuts off or it backs up. Everything else seems to be fine. It just takes a very long time to fill a 20 gallon tank.
Im interested to hear any comments
Old Sep 17, 2008 | 04:32 PM
nicolaselias's Avatar
That only happened to me once at a shell gas station when I left the pump on auto flow... otherwise I have never had the problem...
Old Sep 17, 2008 | 04:50 PM
vegasjetskier's Avatar
I read in another thread that this could be caused by the vent tube being blocked by spider webs and egg casings. Apparently if you look up under the fender you can see the tube, pull it apart, and then blow the clog out.
Old Sep 17, 2008 | 07:03 PM
Also have any of you had the fuel pump replaced lately?
Old Sep 17, 2008 | 08:15 PM
Here's the other thread about the spiders: http://volvospeed.com/vs_forum/index...;#entry1384897
Old Sep 19, 2008 | 12:17 PM
NasS80Tbo's Avatar
I've owned the car for just about a year and the fuel pump hasn't been replaced.
Is that something that should be changed every once in a while?
Old Sep 19, 2008 | 07:59 PM
gordon368's Avatar
its warrantied for like 10 years/150k(something like that)miles the fuel pump that is on the 99-01 models, I got a letter like a few months ago.
Lol by the way I hate spiders, Id hate to be fiddling around doing that and watching a spider jump down on me .. hahahah
Old Sep 23, 2008 | 12:51 PM
NasS80Tbo's Avatar
I had a friend who is pretty savy with fixing cars take a look under my car. He followed a line that was coming the gas tank to what he thought was the 'vent tube'. It was located near the left rear tire. He was able to disconnect one part but could not blow anything out, but he said it seemed like there was something lodged in there. The other end of the tubing was too far in and too tight to dsiconnect. Does this sound like the correct location of this vent tube that can get clogged by webs and spider eggs.
Thanks for the help
ms000
Nov 10, 2013 02:06 PM
Squiggy
Mar 28, 2011 07:44 AM
silver ghost
Mar 1, 2010 11:46 PM
JimKW
Dec 20, 2005 11:26 PM
JimKW
Jun 10, 2005 01:32 PM
