Key FOB battery dies quickly
Old Nov 10, 2021 | 06:51 AM
Scottlaw40's Avatar
Default Key FOB battery dies quickly
2019 XC60: The battery in our key FOB dies within a month. We buy lithium batteries that are fresh and brand name like everready. Antoine know why they won’t last?
Old Nov 10, 2021 | 08:00 AM
ES6T's Avatar
There was a batch of bad remotes. Remove the battery and check the 4 digit code printed on the board. If it's 0142 it will be replaced under warranty if your car is still under warranty.
Old Nov 17, 2021 | 02:34 PM
Scottlaw40's Avatar
Default Volvo service says, no bad FOB reports
[QUOTE=ES6T;504458]There was a batch of bad remotes. Remove the battery and check the 4 digit code printed on the board. If it's 0142 it will be replaced under warranty if your car is still under warranty.[/QUOTE
volvo Service in Fayetteville, NC says no warranty for FOBS. No reports from Volvo saying there are any bad FOBS.
they won’t help us.
Old Nov 17, 2021 | 02:39 PM
ES6T's Avatar
If the fob is one of the ones in the TJ, then they are covered by warranty. Check the date code.
And, if not damaged, fobs are covered by warranty if they fail.
Old Nov 17, 2021 | 03:55 PM
Scottlaw40's Avatar
Default Key fob battery dies
could you please tell me what a “TJ” is? Is there a recall or something Volvo officially identifies the FOB as defective? I don’t have anything official to support my claim. Thanks.
Old Nov 17, 2021 | 07:07 PM
ES6T's Avatar
Technical Journal. Basically a service bulletin. TJ34316 is the one I was referencing.
Did you check the code on your fob? If it isn't 0142, then the TJ does not apply.
Old Nov 17, 2021 | 08:50 PM
Scottlaw40's Avatar
Default Key fob battery trouble
yes, the code on the fob is 0142
Old Nov 17, 2021 | 09:43 PM
Quent AU's Avatar
Here is a link to the Technical document - https://static.nhtsa.gov/odi/tsbs/20...55206-9999.pdf
Old Nov 18, 2021 | 07:09 AM
Scottlaw40's Avatar
Default Key fob battery issue
Thank you for the explanation. Yes, we have the faulty fob code. Now, I need to find a Volvo service center that understands and will help.
Old Nov 18, 2021 | 07:02 PM
ES6T's Avatar
Are you in the US? If so, any dealer should replace it under warranty.
Old Nov 20, 2021 | 05:42 PM
Scottlaw40's Avatar
Default Key fob battery dies quickly
Thanks, I’ll try Raleigh, NC. Fayetteville was no help.
Old Oct 28, 2022 | 02:17 PM
JTibbs25's Avatar
Yes, my 2019 XC90 key fob has the same issues. I even bought the replacement batteries from the Volvo dealer, and still only last a couple months.
Old Apr 1, 2024 | 07:49 PM
DBrueggeman's Avatar
Default Key fob battery drain solution
Solution!!! Finally a Volvo parts guy taught me what I was doing wrong! It’s operator error. In my defense, 3 of the previous dealerships I went to messed it up also. Both of my key fobs kept dying within a month. I was shorting out the battery. Here’s solution!! The two metal prongs on the side have to rest on the side of the battery. Do not push them underneath the battery. There are already two prongs that touch the bottom. If they end up underneath then it shorts out the battery. Also, if you’ve broken off the plastic pieces that hold the battery down, you have to hold the cap in place as you lock the cap back on. Hope that makes sense.
Thank you Vang at Kline Volvo Cars - Maplewood, MN
mjin20176
Jun 25, 2024 02:10 PM
Oprnole
May 6, 2024 09:09 PM
mcgiiver
Jun 28, 2021 08:10 AM
LisaMac8530
Sep 4, 2013 06:25 PM
jparnes1
2001-2013 model year XC70
Jul 11, 2012 02:31 PM
