low battery mssage
Old Mar 13, 2021 | 01:42 PM
Rachid bousseta's Avatar
Default low battery mssage
Hi all,
Volvo XC60 D4 2L Diesel MY 2012:
every time i switch the engine off and let the radio on, a "low bettery" message appear and the system is shutting down in 2 minutes.
but the car start normally after. so i think is a wrong message.
to be sure, i changed the battery, the problem still there.
the diagnostic tool reveal some voltage errors.
is any experiencing this problem ?
Old May 28, 2021 | 07:57 PM
Dece's Avatar
Same problem here 2012 XC60 T6.
Old Jun 5, 2021 | 05:52 PM
E-Volvo-ing's Avatar
Take a look at the "Alternator" thread. It has a video on how to reset the error message.
Hope this helps.
But you should also get the battery tested.
Old Jun 5, 2021 | 08:11 PM
Originally Posted by Rachid bousseta
"low battery" message appear
That is common if the wrong battery is installed in the gas engine cars. ( A size 48/h6 instead of a 92/t7) Not sure what is specified for the diesels. The battery monitor also needs to be reset when changing a battery, or the monitor can be bad. - Easiest reset is with VIDA or a compatible scan tool but is can be reset without (there's a utube out there)
SoS60
Oct 25, 2025 04:18 PM
dougr
Apr 28, 2021 05:37 PM
minsh
Jan 4, 2021 12:58 PM
volvos80t62011
Sep 28, 2016 10:00 PM
JonesDennis
Dec 1, 2013 09:51 PM
