New Volvo Owner With Some Questions
Old Jun 8, 2018 | 09:04 AM
MetroMan76's Avatar
Talking New Volvo Owner With Some Questions
Hello All!!
I just purchased my first ever Swedish car this past Monday.... a 2017 XC60 T6 AWD.
So far so good. I'm used to driving German cars so I'm still getting used to the controls and features.
I did notice that my cigarette lighter power outlets don't appear to work. Is this a setting I need to turn on? I tested the same device in my other cars and confirmed the device works in them so it's not the device.
Also, I notice that when I tune into Sirius Radio, it only scrolls through maybe 5 channels...if I want a certain station I had to actually input the channel number. Is there a way to be able to scroll through all channels at once?
Thanks in advance!
Old Jun 8, 2018 | 12:11 PM
consult your owners manual to determine if there are any controls, but more likely you should check for blown fuse. These cars have multiple fuse boxes so again the manual will be the place to research where the fuse is (you can also find owner manuals online)
Old Jun 8, 2018 | 02:59 PM
MetroMan76's Avatar
Thanks for the reply. I figured out the Sirius satellite channel dilemna by messing with the controls and settings.
I tried checking my oil level and cannot. I looked under the hood and there doesn't appear to be a dipstick. When I try to check it electronically via the dash, it's grayed out. Any ideas?
Old Jun 10, 2018 | 04:52 PM
tony1963's Avatar
You probably have a blown fuse in the accessory port. I believe that the engine uses an electronic oil sensor in lieu of an old style dipstick.
Old Jun 13, 2018 | 10:15 PM
Kajeroberts's Avatar
We purchased a 2018 Volvo sc60 as well. Good luck. We are having all sorts of issues—all to do with the computer.
Old Jun 16, 2018 | 10:21 PM
ETHYL's Avatar
I also have a recently purchased 2018 SC60 T6. No issues at all. A new computer download is available now for no cost. What issues are you having?
Old Jun 17, 2018 | 01:04 PM
Default updates
Well I can’t seem to get the AT&T data plan to work. It wasn’t until I had Volvo on the phone that I even knew it was available. However, it still will not show me which updates are available. It says there are, but when I go into see what they are, nothing there.
Old Jun 22, 2018 | 09:50 PM
MetroMan76's Avatar
Ok, so I figured out how to read the oil level digitally. Now I just need to figure out why the 12 volts don't work.
Old Aug 15, 2018 | 08:14 PM
rickkop's Avatar
Could you please share the procedure for checking the oil? I can't figure it out my manual doesn't list it.
Old Aug 17, 2018 | 10:17 AM
MetroMan76's Avatar
With the engine off, turn on the electronics by pressing the start button.....make sure the engine doesn't turn on. Then on the left stalk, scroll to oil and select ok.
Old Aug 19, 2018 | 03:33 PM
Dixon12's Avatar
Where is it available for download? Volvo says you only get from a dealer with service. Personally, I'd rather not step into a dealership. Like ever. So would be very happy to learn how you can do it without dealing with dealers and all their BS.
Mario Sergio Gomes
2001-2013 model year XC70
Jan 18, 2018 11:48 AM
Juan Hernandez
Jan 15, 2018 04:16 AM
fiey24
Apr 5, 2014 07:10 PM
jimuck
2001-2013 model year V70
Sep 4, 2012 05:12 AM
randall23
Mar 31, 2009 09:29 AM
