Slight vibrations in steering wheel
I sense slight engine vibrations in the steering wheel after a cold start when standing still in P or N gear. Around revs like 1200 but also between 2000 and 3000 revs.
If I start my 2018 T5 (Automatic transmission) I always feel a short slight judder in the car.
You should not feel anything from the engine in the car right?
Does anyone recognize anything as described above?
if you feel a vibration with the car in neutral/park, then you know the transmission/axles are not in play. That leaves a few things 1) the engine is running a bit rough when cold. could be normal or could be due to fuel trim etc. 2) could also be a motor mount or 3) the power steering pump or PS fluid... Does it go away once the car warms up?
