Steering - or maybe AWD? issue
Old Apr 1, 2023 | 12:17 PM
2013XC60T6's Avatar
Default Steering - or maybe AWD? issue
-2013 XC60 T6 AWD with about 80,000 miles. Car has been great so far.
-I regularly have work travel that takes me on 4-hour road trips. After getting off the highway after a long drive, the steering seems “stiff,“ and stiff in the way that a 4WD vehicle feels when it’s locked in 4WD and you try to drive it on the pavement, and make a turn - like the wheels can’t rotate differentially the way they need to in a turn, so one scrubs or skids a bit, which is why you don’t want to drive a 4WD drive locked in 4WD on the pavement so much. So it feels like that.
-I don’t get that feeling after just driving around town or short highway trips, and it does ”loosen up” after I make a couple of significant turns once my long highway driving is over, but the issue returns again the next time I make a long highway drive.
-Thoughts/advice/suggestions/diagnosis?
Thanks.
Old Apr 1, 2023 | 02:41 PM
PixelDust's Avatar
Check your inner tie rods.
Old Apr 10, 2023 | 03:00 PM
2013XC60T6's Avatar
Ok; I’ll have to have that done, as I don’t consider myself competent to do that - but I’ll get it checked. I saw a post someplace suggesting it could be something as simple as a universal joint in the steering column that needs some lubricant; if anyone has had that experience or has a suggestion regarding that, I’d like to hear about it. I had taken it to the dealer for a big service and told them it was an issue, but they claimed they found no issues.
Old Apr 11, 2023 | 11:43 PM
PixelDust's Avatar
​​​​​​If you tell the dealer it's an intermittent issue, they'll never find it. Trust me. Intermittents don't make money.
I suppose you could try lubricant on the universal joints both under the hood near the firewall, and under the dash.
You'll need a long mirror on a stick, a long straw, and some liquid white lithium grease (or something like it) to get the exterior universal joint.
Under the dash, you'll need:
- kneeling pad, ratchet, t-25 torx socket or bit, your grease of choice, small pocket screwdriver, and a bigger screwdriver for prying.
These items will be required to remove the bolster for access to the steering shaft and universal joint.
S806
Nov 23, 2024 11:14 PM
snsrgy611
Sep 14, 2015 12:55 PM
06xc90
Dec 3, 2010 09:54 AM
bluemagicbus
Mar 5, 2008 07:52 PM
domtoni
Nov 28, 2005 03:49 AM
