2010 Volvo XC60 Washer Fluid Sprayer
Old Apr 11, 2023 | 04:23 PM
BisbeeVolvo's Avatar
Default 2010 Volvo XC60 Washer Fluid Sprayer
Hi all,
The washer fluid sprayer on my 2010 Volvo XC60 is very weak, and only coming out of the first sprayer when the hood is closed. When I tested it with the hood open, it sprayed normally from both sides as well as the front headlight washers.
Any thoughts as to what's causing this?
Old Apr 13, 2023 | 02:04 PM
trace the hose from the pump at the bottom of the reservoir up to the nozzles - there are probably a couple of T connections where the hose may be loose. I'd also suspect the hose is getting pinched when you close the hood so look to see if you can see any scars and if the routing is close to the seals where the hood meets the fender/firewall.
itskip
Apr 2, 2022 11:07 PM
fiedel
Mar 8, 2022 07:28 PM
dzevadkis@hotmail.com
Mar 17, 2019 01:03 AM
mmarreco
Aug 6, 2013 02:13 PM
lancecx
Oct 20, 2012 10:38 PM
