Transmission problems?
Old Feb 7, 2015 | 11:58 PM
Hankbaits's Avatar
Default Transmission problems?
We have a 2012 xc60 with the 3.2L. It has 36,000 miles on it. When stopping after it has warmed up after awhile. It has a sharp jerk from stop after taking your foot off the brake and stepping on the gas. Any feedback greatly appreciated.
Thanks,
Hankbaits
Old May 9, 2021 | 07:34 PM
Bobber18's Avatar
I’m having a similar issue with my 2012 S60 T5. But it seems fine if I place the car in neutral while stopping, and then go to “Drive” to move again
Old Dec 18, 2021 | 09:34 PM
chris@cinos.com.au's Avatar
Default Did you fix this?
Thanks,
Hankbaits
hi I have the same model xc60 and am experiencing the same problem. What did you figure out was the problem? Thanks
Old Dec 18, 2021 | 09:42 PM
Bobber18's Avatar
My mechanic says it’s nothing to worry about. You could try changing the fluid or re-programming the TCM, but placing transmission in Neutral and then manually shifting into Drive when the light turns green is a good solution.
Ali B
Sep 1, 2021 09:25 PM
E-Volvo-ing
Oct 3, 2020 08:01 PM
roadRR120F
Jul 18, 2020 03:32 PM
Inspiron742
Nov 23, 2018 10:19 AM
bosea
Jul 26, 2014 09:17 PM
