Whistling from engine bay.
Thank you. I'll try the trick.
Removed the dipstick and the noise was gone, and I heard it sounded like gas burst in (or out) from the opening. Does it mean that the pcv valve is bad?
It means there is something creating vacuum in the crankcase - probably a broken diaphragm in the PCV valve - That is not controlling the flow of vacuum (from the intake) into the pcv system. (in the round part of that box is a diaphragm and a valve - that if broken could be causing your whistling noise)
Understand. I'll replace the PCV valve. Do I also need to replace the gasket in the picture (30731243)? Watched few videos and they didn't mention it.
Call your local Volvo dealer parts department. Tell them you want a pcv box for your car. They will ask for your VIN number, year and model. With that info they will look up the part and give you a price. Ask for the part number and if you are shopping around decide what vendor you want to purchase from. For whatever vendor you choose online it would be best to use one that has a VIN verification system in their website to verify it's the correct part before it is shipped to you.
fiedel (03-08-2022)
