Windscreen Jets intermittent
Old Dec 28, 2022 | 09:51 AM
Satori's Avatar
Exclamation Windscreen Jets intermittent
Hi
​​​​​​2016 D4. Rear and front light jets are working perfectly but the windscreen jets are slow to respond and take a few seconds to work. The pressure is low when they do decide to work it's slightly better than a dribble. Any suggestions as to cause and solution?
Old Dec 28, 2022 | 04:07 PM
I'd start with a sewing pin and try to clean out any setiment from the nozzle, after that I'd look for any signs of leaking due to a bad hose or connector.
Old Feb 14, 2023 | 10:49 AM
Satori's Avatar
Default ****update****
Originally Posted by Satori
Hi
****UPDATE****
Tried a bit of cleaning, flushing and needle poking without success. So I dismantled the jet assemble in the bonnet and found the pressure springs and rubber valve. Cleaned the springs and bingo, pressure restored.
All good 👍
Before and after of the pressure springs taken from XC60 nozzle jets. All three lacked pressure and all three were gunked up like the bottom spring.
NorcalC70
Nov 10, 2021 01:46 PM
JerrySantaCruz
2001-2013 model year V70
Jun 16, 2018 10:01 AM
aruizdelhoyo
Aug 27, 2014 07:00 PM
diehardgator1
Aug 28, 2007 09:46 PM
copurnikus
Oct 17, 2005 10:24 PM
