Xc60 drivetrain
Old Sep 6, 2022 | 01:44 PM
Waltergeo's Avatar
Default Xc60 drivetrain, transmission
I have a 2011 xc60 3.2 with 180000 km on it. About 2 years ago the rear differential started making noises and had to be replaced, not cheap. A few months ago the prop shaft failed and was taken off until I find a replacement part. Carrier bearing failing and can't be rebuilt locally. A few days ago the transmission started making a noise and is definitely a problem. Not impresses with this at all. We bought this car a few years ago with hopes on having a reliable used car. Could I get some feedback on this? How common would this type of problem be?
Last edited by Waltergeo; Sep 12, 2022 at 03:41 PM. Reason: Need feedback or advice
Old Sep 12, 2022 | 09:37 AM
981KMAN's Avatar
Do you have a question, or did you just need to vent? ​​​
Old Sep 12, 2022 | 03:43 PM
Waltergeo's Avatar
Looking for some advice or feedback on this problem. This is a lot of major failures on what should be a reliable car.
Old Sep 13, 2022 | 10:35 PM
where are you located? The drive shaft bearing seems readily available at most suppliers in the US so I take it you have issues sourcing in your local area? As to transmission noises, did the gear oil drain out of the transfer case (aka bevel gear) when you pulled the drive shaft out? What does the noise sound like? does it change with engine speed, road speed, turning at low speeds?
Old Sep 18, 2022 | 12:03 PM
Waltergeo's Avatar
The place I took the driveshaft too said the carrier bearing was not made to be taken off and he saw no way to replace it. The transmission is making a slight noise and appears to be dragging. Didn't try it at any speed. Waiting to get it into a shop for someone to have a look at it.
I live on the eastern end of Newfoundland. A great place to live but not the best for this kind of service.
yaromac
Sep 8, 2022 04:28 AM
Golicza Patrik
Oct 22, 2020 03:38 PM
Floatplane
Oct 30, 2013 07:25 PM
Bluffton
Aug 6, 2011 09:30 AM
