01 Volvo v70 xc
01 Volvo v70 xc Variable Valve Timing Solenoid Testing
Recently have some problems with my v70 xc, it'll crank but wont start. I eliminated many possibilities and am currently going over the Variable Valve Timing Solenoid, but I dont know what its specification of ohms it should be nor its voltage, if anyone can provide an answer for that, it would be most appreciated!!! Also prefer not to go through buying a manual to check, tight on money xD
The vvt gear is driven by oil pressure - you can find some vids on youtube with how to's for cleaning and testing. Not sure if you are associating that with the no-start (doesn't seem a likely cause for a no-start) or just cleaning up stuff. Usually when they fail they just throw a check engine light (for retarded cam timing). What may be worth looking at is the valve timing in general, particularly if you don't know how old the timing belt is. Have you done a compression test?
If you want the best Volvo service manual for free - download the stolen/hacked version of VIDA 2014d and install it on your Win7 Pro computer. The download is easily found, there's an image on swedespeed - All the specs you are looking for are in VIDA, as well as suggestions to solve problems. If you have A dice unit you can plug in and get info directly from the control units and watch live data. A cloned dice unit is about $80.
It takes 3 things for an engine to run
1. Compression- which you have
2. Fuel, what's the fuel pressure?
3. Spark, pull a coil, stick a spark plug in it, carefully ground the plug and spin the engine over - do you see a spark?
Of course fuel and spark have to occur at the correct time -
A possibility on a 2001 is the throttle module not opening, I've seen several seize and refuse to open causing the car to not start. (you need air for the car to run also) The 2001 throttle all went bad as some point - has yours ever been replaced? If you did it you would remember, they can be very expensive. -
A possibility on a 2001 is the throttle module not opening, I've seen several seize and refuse to open causing the car to not start. (you need air for the car to run also) The 2001 throttle all went bad as some point - has yours ever been replaced? If you did it you would remember, they can be very expensive. -[/QUOTE]
Fuel pressure is at 48 i have spark in all 5 cylinders, last time it was replaced was about 3 or 4 months ago
Sorry -
Inexpensive things to do -
Spray starting fluid into the intake and try to start to eliminate ignition/cam timing as a problem.
Check for injector pulse with a noid light - amazon has a pair for $10, maybe find 1 for $5
Make sure the fuel is all gas and not contaminated (I had a large amount of water in a BMW gas tank once - car would not run)
Sorry -
So - you have compression, spark, fuel pressure, injectors are spraying, and starting fluid in the intake causes nothing -
Whats your cam timing? (The mark on the crank gear is hard to see sometimes)
There's not really anything you can check with the throttle (without a scan tool) other than if it's seized - it's a module on the CAN network - So it does not use something simple like 0 volts is closed and 13 volts is open. Here's a wiring diagram - notice there's a fuse for the throttle - the ETM - #7 in the b fusebox sending power to the green/black then changes at the ETM connector to a green wire.
MarkB78
2001-2013 model year V70
07-10-2013 07:21 PM
