01 Volvo v70 xc Crank no start
Old Oct 19, 2020 | 02:28 PM
Christopher07's Avatar
Default 01 Volvo v70 xc Crank no start
As title implies, cranking but no start. Have fuel, spark and air, compression is good, I'm assuming its timing... checking cam and crank sensors. Camshaft sensor signal and Supply is suppose to be 5V so I read. I get the 5V on supply, back-probed and disconnected test. Signal though, I'm getting 5V from the female side only, male side I get 88.7mv (just have the car on). When trying to start the car, I get anywhere between 88.7mv to 2.500 mv. Can anyone help?
Old Oct 20, 2020 | 12:43 PM
do you have any stored CEL codes?
Old Oct 20, 2020 | 12:45 PM
No codes of CEL
Old Oct 20, 2020 | 10:21 PM
ssicarman's Avatar
You say you have fuel. Meaning you have fuel pressure?
Are the injectors working? Power and ground. Check with a noid light on the connectors for the injectors. Install noid light in the injector connector and crank engine. The light should flash.
Old Oct 21, 2020 | 09:40 AM
Dont have the noid light but the injectors are working yes, and I have proper fuel pressure.
Christopher07
Oct 18, 2020 11:00 AM
Christopher07
Oct 17, 2020 02:06 PM
Ross Miner
Oct 3, 2020 07:54 PM
Christopher07
Sep 15, 2020 10:52 AM
venkman
Dec 11, 2015 08:35 PM
