04 XC70 W. Washer Pump Access
Old Nov 16, 2010 | 10:36 AM
Rosew6211's Avatar
Default 04 XC70 W. Washer Pump Access
Windshield Washers quit putting out any water. Have checked washer tubing back to reservoir. OK. Suspect bad pump; however it is below reservoir. How does one access the washer pump for checking. I can't get to it from topside. Help Please.
Old Nov 23, 2010 | 11:05 AM
tr_car_nut's Avatar
The pump is on the outer most edge of the front of the reservoir just behind and down from the turn signal. You will have to remove the plastic splash shield under the bumper to get to it. Once the black plastic is removed you can reach up and push the pump out. You probably do not have to remove the reservoir since it slides up. It's a tight fit.
paulcu
1998-2000 model year XC70
Aug 18, 2014 04:48 PM
DeadLast
1998-2000 model year V70
Mar 28, 2013 09:14 PM
TrouperL
Dec 30, 2012 01:39 AM
blossomdaffodil
Apr 10, 2012 03:23 PM
snulma1
Sep 12, 2007 11:33 AM
