2001 v70 xc engine interchange
Old Dec 30, 2008 | 07:50 PM
seamonkey's Avatar
Default 2001 v70 xc engine interchange
Anyone know if an engine from 98 v70 would work in a 01 v70 xc? Thinking of a project of a 01 xc with bad motor and v70 donor car with good motor. Wiring harness/ecu/trans? Don't care if it stays awd.
Old Dec 31, 2008 | 07:54 AM
Default RE: 2001 v70 xc engine interchange
Im not sure if it would work.
If the donor car was a 99 then it should.
The 98 is a Non VVT motor and the 01 is a VVT motor. That would cause the check engine light to stay on all the time and im not sure of the affect it will have on it running.
Old Dec 31, 2008 | 08:06 AM
Psaboic's Avatar
I have heard of folks swapping 99 and up motors, but nothing earlier than 99. As Tech said, the main difference is VVT vs non-VVT
Old Dec 31, 2008 | 11:03 AM
seamonkey's Avatar
Thank you.
Old Dec 31, 2008 | 11:05 AM
Your welcome.
Old Jan 1, 2009 | 08:08 AM
Psaboic's Avatar
No problem. Hope you can get it all sorted out to your satisfaction
Disco2
Feb 9, 2013 09:31 PM
picelbell
Jan 11, 2009 01:58 PM
markgrne
Mar 1, 2008 10:22 PM
jimnash
Feb 12, 2006 12:28 PM
jimnash
Engine & Internal
Feb 3, 2006 05:52 PM
