2001 xc70 heat
Old Jan 2, 2010 | 12:01 PM
labontefamily's Avatar
Default 2001 xc70 heat
Hi,
I have a new to me 2001 xc70 with 100k miles on it. The car is really nice and everything seems ok except for the heat. It seems fine at idle heating up to the second or third notch on the gauge, but, traveling down the road it runs cooler and cooler the faster you go. The seems to be a direct corelation between temp on the gauge and heat inside the cabin. The air from the ducts never gets more than lukewarm.
This suggests to me that the car needs a thermostat, but, I am not familular with Volvos so I wanted to check here first
Anything I should look for?
Thank you in advance
Ed
Old Jan 2, 2010 | 06:03 PM
family XC70's Avatar
Sounds like your stat is stuck. They are inexpensive and easy to change, I just changed mine because of a coolant temp code on my OBDII scanner.
packetfire
2001-2013 model year V70
Feb 25, 2014 11:09 PM
cooksjohn
2001-2013 model year XC70
Nov 11, 2013 09:04 PM
bbruno
Jul 30, 2009 12:44 PM
Mecheng
Feb 24, 2006 12:25 AM
