2002 XC70 Splattering/Misfiring esp. under load
Old Mar 11, 2018 | 11:14 PM
tonymite's Avatar
Default 2002 XC70 Splattering/Misfiring esp. under load
2002 XC70 Splattering/Misfiring esp. under load - changed 2 coils, haven't attempted OBD reading via laptop (yet) ... Plugs seem(ed) OK, Air Flow Meter readings via Multi-Meter look steady ... have yet to check fuel pressure but seems more like an intermittent spark issue...
Any thoughts?
Old Mar 12, 2018 | 07:40 PM
tonymite's Avatar
P.S Every now and then during gear changes, it does exhibit puffs of black smoke (un burnt fuel) out the back..
Old Mar 12, 2018 | 07:46 PM
tonymite's Avatar
Is there a way of reading the codes without OBD2 instrument/PC/Laptop (software) i.e bridging pins on OBD connector and reading flashes somewhere say on dash or computer??
Old Mar 13, 2018 | 12:50 AM
tonymite's Avatar
P0700 VOLVO - Transmission Control System (MIL Request)
P0300 - Cylinder Misfire Detected Random Cylinders
P0302 - Cylinder 2 Misfire Detected
P0134 - O2 Sensor Circuit No Activity Detected Sensor 1 Bank 1
P0304 - Cylinder 4 Misfire Detected
P0303 - Cylinder 3 Misfire Detected
P0305 - Cylinder 5 Misfire Detected
P0301 - Cylinder 1 Misfire Detected
Going by MY Logic - I'd say O2 Oxygen/Lambda Sensor as it says "No Activity Detected" and I wouldn't suspect ALL cylinders be affected. Is there a resistance reading to check whether O2 Oxygen/Lambda Sensor is faulty on its own?
Old Mar 1, 2020 | 06:40 PM
jpadcap149's Avatar
Smile Throttle Body ?
I had a 2001 V70 doing the same thing,,,,very little power, too....replaced the throttle body and all was good.
Old Mar 5, 2020 | 07:28 PM
hopefully after two years tonymite got his car sorted out. It all comes down to spark and fuel. If the metering is off, so's the power. if the spark is too cold, so's the power. Not a one size fits all for diagnosing misfires so it helps to have a sense of how the systems work and what the common problem areas are (like the ETM contacts...). Curious how you homed in on replacing the ETM. Good to see you got yours fixed up.
Andrew Fritz
May 9, 2020 08:28 AM
Galaxy850Sunny
Jul 19, 2014 10:43 AM
skatermattc2
Sep 2, 2010 02:17 AM
newfsowner
Feb 11, 2007 09:38 PM
