2008 xc70
Old Dec 17, 2010 | 04:09 PM
MCGHS's Avatar
Default 2008 xc70
Ha anyone had their windsheild washer filler neck gasket replaced under Volvo warranty. When I fill me liquid level to point where I can see the fluid in a couple of seconds it is on the ground.
Thanks in advance for your responses - MCHGS
Old Dec 18, 2010 | 10:20 PM
stonepa's Avatar
Yes - this is typical of all Volvos in my experience. My 960 also did it. The washer bottle is made of 2 pieces -the tank and the filler neck. They removed the gasket from the later design and it now leaks if it is not pressed together correctly. I had mine replaced under warranty and now no problems.
Have them check the high pressure washer hoses to the headlamp washers. There is a service bulletin on these as they sometimes leak also. Once they fix it you should be good forever.
Old Dec 19, 2010 | 02:19 PM
MCGHS's Avatar
Default Leaking Washer Tank
Patrick,
Thanks for your reply. Tomorrow I am going to make an appointment with my local Volvo dealer and mention the headlight washer hoses as well as the filler to tank connection.
Thanks again,
Rich
Mighty Quinn
Mar 30, 2009 09:26 PM
Mighty Quinn
Mar 14, 2009 10:44 AM
audiobiz
Jan 2, 2009 05:27 PM
JRXC70
Mar 25, 2008 06:03 AM
torres
Jul 16, 2007 08:53 PM
