2008 xc70 abs module
Old Dec 10, 2022 | 07:58 PM
Newfoundvolvo's Avatar
Default 2008 xc70 abs module
Have abs and traction control lights on the dash , and the odometer isnt working . Speedometer works fine so im led to believe that would indicate a faulty ABS module correct ?
Old Dec 10, 2022 | 09:05 PM
Here again your first step would be to scan the car with a compatible scan tool that can scan ALL the control units in your car. Then from that info develop a rational/reasonable diagnostic path. (if using VIDA as a diagnostic tool - VIDA will give you suggested solutions for each code)
Old Dec 10, 2022 | 09:08 PM
Car didnt have any codes aside from oxygen sensor issues
Old Dec 10, 2022 | 09:30 PM
What scanner are you using?
Old Dec 10, 2022 | 10:26 PM
not all scanners read ABS codes and there are other components like the individual wheel speed sensors that can throw fault codes. See if you can get a free scan from an Autozone or a volvo friendly Indy.
ABVO850
Aug 10, 2012 02:25 PM
rcvolvo
Jul 31, 2012 10:20 AM
matt01
Jul 15, 2012 06:18 PM
EATMAN
Jan 29, 2009 12:50 PM
darimik
Jun 24, 2008 08:03 PM
