98 XC70 P0131 and P0137 on help
Old May 28, 2009 | 05:39 PM
mamali's Avatar
Unhappy 98 XC70 P0131 and P0137 on help
Hi We replaced both oxygen sensors. The first plugged in 2nd had the be spliced. Before the replacement there was P0131 now 2 codes!!!!!!!! Help I am confused. The reason second sensor was spliced is because someone cut the connector!!!!Thanks
Old May 28, 2009 | 06:54 PM
Have you tried clearing them and driving it again?
Sometimes the computer takes a few drives to recalibrate the repair.
Old May 28, 2009 | 07:25 PM
mamali's Avatar
Default Clear code
Yes tried a few times still the same problem.
Old May 28, 2009 | 07:26 PM
Maybe it might be the sensor or how you wired it up.
Volvo's really do not like spliced O2 senors.
Old May 28, 2009 | 07:31 PM
mamali's Avatar
I tried buying a connector Volvo wants to sell me a whole new wiring harness at $1300.00 Ouch.
Old May 28, 2009 | 07:36 PM
Yes ouch. Maybe try redoing the connection and see if it gets better.
Old May 28, 2009 | 07:44 PM
mamali's Avatar
We have tried and tried could the computer be bad?
Old May 28, 2009 | 07:48 PM
Possibly but then it would have had the 2 codes before instead of the one. That's why I was leading to the wiring.
But since it is a 98 if you can find a used computer cheap try it.
Old Jun 1, 2009 | 03:57 PM
V70-T5's Avatar
you might try to see if you have a bad ground or open in the harness the 02 sensors get plugged in at
Old Jun 3, 2009 | 03:56 PM
mamali's Avatar
Default Volatage
Hi any one know how many volts the oxygen sensor is supposed to receive. There are 2 ground wires and 2 live. Thanks
Old Jun 3, 2009 | 07:33 PM
If it is unplugged I believe it gets a 5 volt reference.
Old Jun 4, 2009 | 08:46 AM
mamali's Avatar
Thanks 2 volts each and 2 ground.
Volvo850Rookie
Aug 20, 2015 04:46 PM
Fishjay
Jun 3, 2014 12:35 PM
Fishjay
May 24, 2014 11:24 AM
mamali
May 28, 2009 01:36 PM
rob960
May 17, 2006 11:04 PM
