99 xc70 Mystery Misfire - Help
Old Jan 10, 2010 | 11:38 AM
fuelcell_1's Avatar
Smile 99 xc70 Mystery Misfire - Help
Hi, So my 99 xc70 starts running really rough in the middle of going up this hill, loose power, flashing cel.
I check the code when i get home and get a p0304. So i replace the always failing ignition coils and all the plugs. But, that didn't do it. I still get the code a really rough engine.
What to check next??? Tks
Doug
Old Jan 21, 2010 | 12:04 AM
CRW's Avatar
CRW
1)Fuel Pressure
2)Fuel Flow
3)Injector Flow
4)Compression
5)Fuel Trims
6)Vacuum Leaks
7) MAF proper value
A code does not tell you what is wrong with the car it only tells you what the symtoms are, you must figure out what the issue is without throwing parts.
urbanfundamentalist
2001-2013 model year XC70
Mar 21, 2014 09:26 AM
ssrob
May 26, 2011 07:00 AM
98XCFxRUpR
Oct 4, 2010 12:37 PM
TealTank
Apr 6, 2008 09:37 AM
