ABS failure
Old Oct 11, 2008 | 09:30 AM
Teachrz's Avatar
Default ABS failure
I had the tell-tale "brake failure stop safely" message with the other dash lights and the loss of odometer and cruise control on my 02 xc70 so I ordered a used controller from Erie Vovo. After installing it I still have the same error, but my ABS seems to work (I hit the brakes on a gravel road). Any suggestions?
Old Oct 11, 2008 | 09:48 AM
Default RE: ABS failure
Maybe the one they sent you had codes stored in it.
Try having the codes cleared.
Old Oct 13, 2008 | 08:44 AM
Psaboic's Avatar
If clearing the codes does not work, I would check for a bad connection and or pinched/broken wire
jasonthaynes
Dec 2, 2012 05:32 PM
cswadner
Oct 11, 2009 08:08 PM
jg1
Mar 16, 2009 08:08 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
