Brakes
Old Jul 25, 2006 | 07:11 PM
jtkelley3's Avatar
Default Brakes
I just had the front and rear pads and rotors changed on my '02 XC70. A question for those of you in the know. I believe that I was probably a little late in changing things this go around. In the future, could I just change the pads and not have to buy new rotors, or is this something that I am going to have to do every time? Thanks for all the help!
Old Jul 25, 2006 | 10:48 PM
Default RE: Brakes
You should get atleast 3 to 4 Pad changes to a set of rotors.
They can be measured each time and compaired to the Min. Specs.
Make sure you don't go metal to metal or you will have to relpace them each time.
Old Jul 26, 2006 | 10:58 AM
jtkelley3's Avatar
Default RE: Brakes
Thanks for the help. I do mostly city driving in our wonderful metropolis of Baltimore. Should I be measuring the pads every six months or so?
Old Jul 26, 2006 | 08:46 PM
Default RE: Brakes
Just have the rotors Measured every time you need pads. And have the Pads inspected every oil change.
Old Jul 29, 2006 | 03:06 AM
Red XC's Avatar
Default RE: Brakes
What I do when servicing these vehicles for brake inspection. I take a look at the pads, then look at the rotors if any scratchs,etc. If there was a complaint, I will go into further diagnosis. Also, if you see your rotor are very dished, its time to replace them. Thats just my opinion.
netconcepts
Feb 10, 2005 08:51 PM
Air Defender
Jan 29, 2005 07:45 PM
djbaines
Nov 10, 2004 06:43 PM
jhenry83
Aug 31, 2004 05:57 PM
midnight
Jun 29, 2004 05:51 PM
