Front Brake Service
Old May 10, 2008 | 06:19 PM
dcandmc's Avatar
Default Front Brake Service
Can anyone give me any hints/tips/tricks on a DIY front brake job? I have a 2004 XC70and I need to replace the front rotors and pads. How difficult a job is this for someone with no specialized automotive tools and average mechanical ability?
Old May 10, 2008 | 06:28 PM
Default RE: Front Brake Service
It is pretty easy and straight foward.
You will need a 7MM allen for the caliper bolts.
You will need a 15MM socket for the caliper bracket bolts.
You will need a 10MM wrench or socket for the rotor hold down bolt.
You will also need a screwdriver and pliers for installing the spring.
Old May 10, 2008 | 09:25 PM
dcandmc's Avatar
Tech-
I appreciatethe quick reply. A few questions, if you don't mind:
1. Will I have to bleed the brakes after the new pads and rotors are installed?
2.Will I need to use brake grease and/or brake cleaner?
3. I have 16" inch wheels. What size rotors do I have, and can you recommend any particular brand and supplier for the rotors and pads?
Thanks.
Old May 10, 2008 | 09:34 PM
1.No bleeding you are not opening the system.
2.Brake grease on the back of the pads.
3.Not sure you could have both sizes measure the ones on the car.
Buy Brembo or Zimmerman rotors.
Old May 11, 2008 | 09:46 AM
Psaboic's Avatar
A couple of tips I always tell first timers regarding brakes. 1. Take your time and try to keep the new parts as clean as possible. 2. Take apart only one sideat a time. That way if you forget how something goes back together, you can always look at the wheel you haven't taken arat yet.
Glenn
Old Jul 11, 2008 | 07:08 PM
SoCalNetworkPro's Avatar
Just did a front-end brake job. ...used EBC Brakes and Rotors...I will let you know how they are...
robingichuhi
Feb 22, 2017 04:34 PM
rolling2
Oct 20, 2010 01:08 AM
chrissygm
Sep 30, 2008 05:53 PM
booyaolian
May 24, 2008 01:37 PM
