Fuel Tank small evap leak
Finally gave up trying to find the small evap leak. I had the computer updated, changed the pump and purge valve and had it smoked to no avail. Broke down and took it to the dealer. Tank is leaking where the lines ,which are molded ,exit the tank. 45,000 mile 2007 model. Repair is going to be $2,650. Has anyone else had this problem. Seems to me this that this is a part that should not fail due to normal driving and vibrations . It's either a manufacturing or design defect. Do I have a case?
Yes. They said there is molded section where the lines exit. Im in a bad spot have no choice at this point. I will ask for the old one.
poor_red_neck
Jun 27, 2010 09:03 PM
